#7 Re: Don't do what I did.
Posted on: 2004/8/12 13:40
and yet petrol is the cheapest option per litre when you need it and the car already has it in there
#6 Re: Don't do what I did.
who_your_datty_1200 Posted on: 2004/8/12 7:34
Or try an orange/lemon based cleaner, works a treat on oil.
#5 Re: Don't do what I did.
Reeves Posted on: 2004/8/12 7:29
Get a ew bottles of engine cleaner like Prepsol, clean green, etc.
Easily available and cheap.
Oh and dont forget the broom, a hard bristled one.
#4 Re: Don't do what I did.
Posted on: 2004/8/11 12:46
nothing beats petrol and an old broom.
#3 Re: Don't do what I did.
DatoRacer Posted on: 2004/8/11 9:22
Simply Green concintrate which you can buy from Repco or Harware stores works well. just spray on and scrub and then hose off.
#2 Re: Don't do what I did.
rx_thug Posted on: 2004/8/11 7:29
pour some petrol on it and sweep it into it, then get some sawdust onto it. it should lift it all
#1 Don't do what I did.
A14force Posted on: 2004/8/11 7:18
A bloke I met gave me a 1200 rolling shell. He had cut out repair patches for his other car. I have just finished stripping all the reuseable parts. Instead of paying $25 , or whatever it is To get it taken away, I elected to cut it up into bits small enough to fit on the back of my ute/ in my trailer.I borrowed an axe from work and took to it after work today. I chopped the roof off, and then cut it into four quarters. Unfortunatly when I rolled the front half over to cut it down the middle, I didn't think about the sterring column, which I haven't bothered removing. The result was a nice pool of gear oil in the driveway. I hate gear oil, it smells BAD!
So if any of you are dismembering a wreck bear in mind the oil.
Do any of you know any good tricks for removing gear oil from concrete driveways?
