Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: Whistle noise when i have the clutch down.
Posted on: 2004/11/11 16:08
Serious problem? Not if the sound went away. If it returns, and if gets worse, then you might re-consider. No worries.
"Thrust bearing" is also the term used for the middle crankshaft bearing ofthe A-series engine. It controls the fore-to-aft play of the crankshaft. So keep in mind the word has two meanings depending on which country you are in.
#6
PVG070
Posted on: 2004/11/11 9:37
Alright, well the noise isnt there anymore.. guessing it hasnt gone away.. is it series problem?
#5
A14force
Posted on: 2004/11/11 9:34
Same thing. We call 'em thrust bearing down here,
#4
Posted on: 2004/11/11 7:27
The thrust bearing is inside the engine, isn't it?
The throwout bearing is on the clutch lever arm. Nissan calls it the "release bearing". It's #4 in this picture: Clutch
#3
selfwedge
Posted on: 2004/11/11 7:21
throwout = thrust bearing?
#2
Posted on: 2004/11/11 7:16
The throwout bearing is bad. Got to remove the transmission or engine to replace it.
#1
PVG070
Posted on: 2004/11/11 6:20
When i have my foot on the clutch it whistles... it pretty noticeable..
whats the go? You can view topic.
