Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#3
Re: motor/gearbox remove
boofhead
Posted on: 2005/2/15 8:01
also helps heaps if you jack the rear of the car right up off the ground so you can pull the tailshaft end of the box trough the engine bay with out it hitting the ground and getting the whole lot wedged in the engine bay with nowhere to go
also pull out the radiator.
#2
COUP1200
Posted on: 2005/2/14 23:38
You can remove them both together but drain the gearbox oil first
#1
uterous
Posted on: 2005/2/14 15:47
Am I able to remove the motor & gearbox at the same time or will i have to do one at a time???
