#9 Re: ping,knocking woes
killer1200 Posted on: 2005/3/16 8:20
what about your coil and plugs
the block of wood wasn't that badder idea
#8 Re: ping,knocking woes
nicholas Posted on: 2005/3/16 7:59
it was funny!!
i've used 4 tanks of differant fuel and still the problem is there.?????????
only one the last bit of throttle does it start to give sh1t, otherwize it's fine
#7 Re: ping,knocking woes
killer1200 Posted on: 2005/3/16 7:55
does his aways happen ?
you could have just got some bad fuel
#6 Re: ping,knocking woes
benny Posted on: 2005/3/16 7:40
the block of wood is the dumbest idea i have ever heard
I'm pretty sure it was intended to be humorous, rather than serious. I thought it was funny
#5 Re: ping,knocking woes
nicholas Posted on: 2005/3/16 7:24
it's 125psi running on 7psi of boost, so thats fine compression is set to 10 degrees, but should be 15 degrees.
#4 Re: ping,knocking woes
killer1200 Posted on: 2005/3/16 6:30
is this engine running big comp ?
#3 Re: ping,knocking woes
NIS15L Posted on: 2005/3/16 6:26
Either needs more fuel or less timming.Just needs a good tune by the sound of it.
#2 Re: ping,knocking woes
sidedraught Posted on: 2005/3/16 6:19
Not a problem.
Glue a block of wood to the back of the accelerator pedal that will limit the travel by one eighth.
#1 ping,knocking woes
nicholas Posted on: 2005/3/16 6:15
those of you that have had this problem,when did it happen? and what did you do to sort it out?
on my e15et the last bit of throttle gives me pinging if i back off just one eighth it's fine, so what do you think it could be?
