Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#6
Re: Again with the carby
Ryno
Posted on: 2005/7/19 9:06
no its the original factory carby. i will try the gasket tonight see how that goes. other than that i am stumped.
#5
Team_Dat
Posted on: 2005/7/19 5:01
is it the factory Hitachi carb or an aftermarket one?
#4
ubu_nation
Posted on: 2005/7/19 4:37
Had same problems witha 32/36 weber on my 180b - it would idle realy bad but run fine under load - Turned out to be a vacume leak where the carby mate's the inlet manifold. New gasket fixed the problem. worth a try??
#3
Ryno
Posted on: 2005/7/18 12:21
the throtle body was working only two days earlyer on another carby it all looks as if there is no play in the throttle body.
#2
Dodgeman
Posted on: 2005/7/18 12:00
Is it worn in the throttle shaft & bushes? If so, you will never be able to fully control the mixture at idle, so have a look at that.
If the shaft flops around in the housing, then, depending on the make & model of carb, it may be easier to find a carb in better condition & use only the base as a replacement since you have already freshened up the rest of your carb.
#1
Ryno
Posted on: 2005/7/18 10:06
Once again i am having trouble with my carby after getting a pro to overhaul the carby and muck it up. I decided to have a go myself and it all went well until i got it running but the adjusting the mixtures really does very little. It will stall when you come to a stop and idles funny other than that that it runs fine on the open road?
Any ideas? You can view topic.
