#16 Re: Release bearing issues
dattodevil Posted on: 2005/8/25 11:28
It breaks out in 3rd gear, So I think I would need a LSD before I took it racing
#15 Re: Release bearing issues
nzdatman Posted on: 2005/8/25 11:26
good on you Damon. Now bring it up north to Taupo's new circuit and we'll have a race!!!
#14 Re: Release bearing issues
dattodevil Posted on: 2005/8/25 11:05
I think you'ld be right And guess what, My ute goes HARD now
#13 Re: Release bearing issues
A14force Posted on: 2005/8/25 11:00
I thought that the sandwich plate was supposed to help spigot the startermotor in the right position. Whan I haven't used one the starter pinoin/ring gear mesh has sounded awful.
#12 Re: Release bearing issues
dattodevil Posted on: 2005/8/24 9:04
I don't remember seeing a 5mm alloy plate, Mine has a pressed steel one which would make 1 maybe 2mm difference.
#11 Re: Release bearing issues
b310gx Posted on: 2005/8/24 8:43
easier way to get the throwout bearing closer to the pressure plate is to remove the 5 mm thick alloy plate,which is purely a cover to keep
rubbish out of the clutch assembly.you can get a half moon shaped plate from a sunny auto,which will bolt in,or use the stock 1200
one & just drill the holes out to 10 mm.this will also give a little more clearance around the transmission.
#10 Re: Release bearing issues
dattodevil Posted on: 2005/8/24 8:33
Ok, here's a picture on what was modified, body extended by 7mm, could have gone a touch more but it works with a brand new clutch, so no problem there.
#9 Re: Release bearing issues
hotrod88 Posted on: 2005/8/23 11:56
sounds like you have it all sorted out, but some good advice from exp. Better take notes on all your modifications for later reference. I have done lots of modifying and later on had to replace some parts and got year model parts mixed up,lol
#8 Re: Release bearing issues
dattodevil Posted on: 2005/8/23 8:43
Ok, I have pulled the gearbox out and measured the difference between the two. I get 7mm which means a spacer just wont cut it (as the shank is only 12mm long), so I have sent it to my engineer who will modify 2 to make one, unless of course someone has a long A12 one in Christchurch
#7 Re: Release bearing issues
dattodevil Posted on: 2005/8/22 9:05
I am presently looking at either fitting a spacer or finding an A12 carrier. I have three gearboxs here and they all have the same carrier, but I doubt they all came off the back of an A15. Does anyone know the exact measurement difference between the two? I was thinking maybe 5mm?
