Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: 1200 brakes q.
sidedraught
Posted on: 2005/9/1 7:38
If your drum brakes are correctly adjusted and in working order they should stop the car very well.
Also 120y brakes are a bolt on and fit under 12 inch wheels.
#6
Re: 1200 brakes q.
gx1200
Posted on: 2005/9/1 6:29
Hey there, being a sedan with drums, ( im asuming we are talking on the front) you could always just bolt on a set of coupe disc brakes, they will fit behind the hub caps and if its a "a" series motor, this should provide good braking with out effecting the look of your car and for a relitivly cheap price. Good luck. Cheers. Adam.
#5
Re: 1200 brakes q.
woodydat
Posted on: 2005/9/1 6:09
true, but i couldnt understand his typing,
whats in ur sedan? engine wise?
#4
Re: 1200 brakes q.
L18_B110
Posted on: 2005/9/1 1:13
woodydat, I think he meant the hubcaps
I've fitted a set of 12*5" mags over my Stanza struts for a laugh a few years ago... But I don't know if the standard 12" steel wheel will fit.
#3
Re: 1200 brakes q.
Posted on: 2005/9/1 0:06
"Man, with typing like that, you must have 3 things rong."
woody dat, drop the attitude and just answer if you want to but not this kind of thing........i could say learn to spell but that would not be constructive would it if you do stanza upgrade, you will need to upgrade to 13inch rims....
#2
Re: 1200 brakes q.
woodydat
Posted on: 2005/8/31 14:53
#1: Your smashed off ur guts. #2: You never went to school. #3: You have really fat fingers. Or, all of the above. Ur not going to be able to keep the same hubs. u can try a 120y disc brake front end. they go in pretty easy. or u can try a stanza conversion, also relativly easy, or theres 200b upgrade even 1600 strut upgrade, but they are difficult. use the search bar to ur left. its got heeps of info.
#1
1200 brakes q.
DATSIN
Posted on: 2005/8/31 14:48
hey all,
i was wondering wat sorta brake upgrade(calipers and rotors) would fit behind my standard 1200 ssedan hubbies? i wanna keep the hubs but being a sedan with drums i wanna actually stop. haha wat sorta struts could i use? cheers DATSIN You can view topic.
