#7 Re: Old engine: Pistons stuck in cylinders / block
Mildman Posted on: 2005/9/11 14:40
Hey all....still a bit stuck after some penetrating spray, and a bit of belting.
Crank is off, you can see here:
Block n pistons
More of the process to get to here has been documented too...just for the hell of it.
The engine strip down
I'm going to get some wet n dry sandpaper and try and get rid of a bit more of the rust that way...then see where I stand.
Appreciate the help.
#6 Re: Old engine: Pistons stuck in cylinders / block
120fly Posted on: 2005/9/9 11:04
Turn the block upsidedown drop some dryice into th skirt cup it may help shrink the piston enogh to delodge it after a good soaking in crc or wd 40
#5 Re: Old engine: Pistons stuck in cylinders / block
pro-240c Posted on: 2005/9/9 10:06
take the crank out.
beat the sh1t out of the piston with a rubber mallet.
and for god's sake, if you don't have one - don't hit it with a normal hammer. use a block of wood or whatever.
:edit: oops - i just saw b310gx's post. sorry...
#4 Re: Old engine: Pistons stuck in cylinders / block
Boostin Posted on: 2005/9/9 5:09
I agree.. Drench it in CRC or WD40 and leave it for a day, maby two....
#3 Re: Old engine: Pistons stuck in cylinders / block
b310gx Posted on: 2005/9/9 5:01
i agree,let the bores soak in penetrating oil
overnight.when you go to remove the pistons,turn the block upside down & tap the pistons out with the handle of a hammer.that is,hold the head of the hammer(lots of h's in there),in your hand,then tap down.if the pistons dont come out easily,get a piece of wood & put it on the piston,then hit the piece of wood.don't ever hit the piston directly with the hammer head,even if you're not planning to
reuse the pistons.
#2 Re: Old engine: Pistons stuck in cylinders / block
MRSR1200 Posted on: 2005/9/9 0:56
hay ther mate..
a hone probly wont help u mutch coz u will hit the pistons and mybe damage the hone depending on wat type u get.. i recon first try spraying all the bores with WD40 or sun sort of penetrating lube 2 brake down the rust.. spray it and maybe even leave it over nite and try the next day...and just make shor as u push them up from the bottom the rod duzn get stuck.. suntime u have 2 tap the pistons up with a dolly or soft hammer...
#1 Old engine: Pistons stuck in cylinders / block
Mildman Posted on: 2005/9/9 0:40
Hey all,
I've been stripping down an A12, to then put back together again - all as a learning process.
Now I've come this far I'm considering rebirthing it. New gaskets, clean up all the old parts....
The probelm is the cylinder bore is a bit rusty and the pistons are not keen to come out of the block.
I thinking of buying an engine cylinder hone today to rip out all the rust....what I'm wondering - is there a better way to get these pistons out?
