Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: a12 GX inlet/exhaust gasket
dattoman_1000
Posted on: 2005/9/22 12:59
I buy my big port ones from JTS
On my 3rd one this year..... don't ask I usually get 2 at a time too..... helps to have a spare.
#6
boofhead
Posted on: 2005/9/22 12:32
hey pigdog, give me a call tomorrow (friday) i've got a couple gaskets you can have if they fit.
cheers
#5
B120dat
Posted on: 2005/9/22 11:46
Hey mate.
For my A14/A12gx head i got my Gasket from: Stewart Wilkins Rallying Ph: (02) 4577 2400 swrallying@ozemail.com.au There a great quality gasket metal gasket composite with metal inlet surroundings They cost $22 each back then (2years ago) P.s Buy two you never know when you may need one in the future or incase of accidents ( I still have my spare one to date)
#4
A14force
Posted on: 2005/9/22 10:59
I disagree. The GX head has taller intake ports. If you dont agree Ill post a pic.
#3
1200rallycar
Posted on: 2005/9/22 5:29
they are the same as a-14/15 manifold gasket, can get a gx one in bayswater (SE melb) if need be
#2
blofly
Posted on: 2005/9/21 7:09
the rest of the engine will be the same as a standard A12 engine. The GX engine has oval intake ports and two studs at the top of each pair of intake runners, the bottom end is the same except the crank is balanced and runs 10.0:1 compresion ratio. I would suggest you try http://www.swmotorsport.com/enginegskt.htm
for all your parts as he seems rather cheap for prices
#1
PIGDOG
Posted on: 2005/9/21 2:34
Just wanting to know where i can get one for a rebuild that im doing.
I assume that a normal a12 gasket set will be fine for the rest of the engine You can view topic.
