#4 Re: Best Carburettor to use when boosted
Tyrie Posted on: 2005/10/28 9:07
In that case could you use the charade carby hat/box on other carbs? I'm sure boxing out a carb isnt the easiest thing to do.
#3 Re: Best Carburettor to use when boosted
pro-240c Posted on: 2005/10/28 8:32
you can box out a 32/36 - apparently they work well. i'd steer clear of a charade carby - designed for economy not power.
or a small 180 edelbrock or something i guess could be made to work.
some of the alfa blokes have a lot of luck with blow thru DCOE style dellortos...?
#2 Re: Best Carburettor to use when boosted
Tyrie Posted on: 2005/10/28 8:18
I've heard the Blowthrough carb off a Charade turbo bolts on... can anyone verify?
#1 Best Carburettor to use when boosted
chris1200t Posted on: 2005/10/27 13:45
Gday fellas i was courious to know what carby was best when it is used under boost (blowthrough) cheers
