#5 Re: GX Bottom end
blofly Posted on: 2005/11/8 9:15
all I know is that the GX bottom ends were 10.0:1 compression ratio and they were balanced the block also had slight cut outs at the edges of the bores to allow clearance for the exhaust valve lip
#4 Re: GX Bottom end
PIGDOG Posted on: 2005/11/8 9:01
so it is normal for it to have standard pistons then.
anyone have enything to say about using the GX bottom end, compared to the standard one?
#3 Re: GX Bottom end
ddgonzal Posted on: 2005/11/8 5:05
The article should be updated.
There were two GX pistons: low-gas and hi-gas. See: A12 GX Compression Readings
#2 Re: GX Bottom end
matbighat Posted on: 2005/11/5 4:02
This is news to me.
#1 GX Bottom end
PIGDOG Posted on: 2005/11/5 3:13
as i was reading through the tech section i noticed that it says that 1200GX's have flat top pistons, is this correct, as my one has the same pistons as a standard 1200 a12.
Also as i am planning on using the standard 1200 block, crank, pistons, conrods. i was wondering if i should use the GX stuff, it doesnt really look any different to the standard stuff. except that the GX conrods look to be a it stronger, but also slightly heavier.
Any opinions?
