Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#8
Re: Decompresion plate???
A14force
Posted on: 2005/11/14 7:22
Muck up the rocker geometry? The shims come in .7mm and 1.5mm. All you do is adjust the tappet to compensate.
#7
pager
Posted on: 2005/11/14 1:41
cost
don't forge pistons cost abit (1000+)??? yer thought the would muck up the valve train. can you buy shorter rods?? are they cheaper
#6
COUP1200
Posted on: 2005/11/13 22:46
Stay away from them. Decompress it properly. using a decomp plate could stuff up all the rocker geometery.
If your running big boost put forgies in it anyway. You mayaswell build it reliable coops
#5
pager
Posted on: 2005/11/13 22:28
yep a turbo. any ideas how thick i am aiming for around 7.5-8:1 comp. yep its gunna be big boost.
#4
qik1000
Posted on: 2005/11/13 3:38
I don't think the pistons are weak, but I've never played with A12's. A decompression plate will reduce the squish clearance and may infact promote pre-ignition rather than retard it. What's the puropose ?? Turbo ???
#1
pager
Posted on: 2005/11/12 4:49
Thinking of a cheaper way to get lower compresion in an a12 rather than buying forged pistons. if i use a decompresion plate will it affect the valves??? an how strong are the standard pistons? i have heard they are a bit weak. thanks guys
