Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: What are these gaskets for?
Mildman
Posted on: 2005/11/16 13:35
Excellent help guys...I belive the mystery is solved. I'll list them all on the web page now with a little more confidence.
The help for all here turns a really hard job into something reasonable and fun too! Thanks again.
#10
ade
Posted on: 2005/11/16 7:53
dizzy o ring , white one is for the oil pump ( only if you are splitting the body) the two gaskets go on either side of the fuel pump block.
and as for the extras it is cheaper to produce and stock one gasket kit to suit 4 engines than to have 4 gasket kits on the shelf cheers Ade
#9
Keith
Posted on: 2005/11/16 3:42
2332 owner is right about the fuel pump, both sides of the spacer.
The thermostat housing gasket depends on if you have air injection or not. It will have 6 holes.
#8
Keith
Posted on: 2005/11/16 3:37
The o ring is for the dizzy
the top right is for the EGR valve The middle one is for the EGR passage (piece that attaches to the inlet mani and the EGR valve bolts onto it) This I know for sure
#7
2332owner
Posted on: 2005/11/16 1:45
Maybe on both sides of the fuel pump spacer?
#6
Mildman
Posted on: 2005/11/16 1:36
I'd say the consensus is the top one if for a fuel pump (the shape looks just about right) - although there is another fuel pump gasket in the kit (in the other photo) and I have two of them.
The bottom does indeed look like an oil pump shaped gasket (although I have another oil pump gasket in the kit). Middle one is reported as EGR here...we'll run with that. The only mystery for me know is why I get two identical fuel pump gaskets? Maybe I'm expected to put both on, but I wouldn't think so Thanks for the help guys.
#5
1200coupe
Posted on: 2005/11/16 0:28
The o-rings's for the dizzy, the bottom one looks like an oil pump Yep spot on. Then the top one is for the stock fuel pump and the one in the middle also looks like a fuel pump gasket although it wont fit your A series.
#4
gx1200
Posted on: 2005/11/16 0:24
Hey there, the other two gaskets are for the EGR on an A15 motor. Adam
#3
2332owner
Posted on: 2005/11/16 0:18
The o-rings's for the dizzy, the bottom one looks like an oil pump, and I've always wondered what the other two are for too. Never needed them, but they've been included in every set I've bought thus far.
#2
teretonga
Posted on: 2005/11/16 0:01
Did you buy a universal A12-A15 set? If yes then you will have gaskets to cover all variations e.g thermostat housing differences on the A14 N10 motor and the A14 RWD motor. Just grab the ones you need - you always end up with extras in these multi packs.
