Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: Side'es on an A14
nicholas
Posted on: 2005/12/13 15:50
to start of with the motor won't be able to flow those carbs, as it is bog stock, these A-12's you talk about must be full on race motors??
if the jetting is not right(flooding) he will end up washing the oil off cylinder walls, not to mention diluting the oil in the sump. widget get hold of me i have a exellent book on tuning side draughts.
#6
teretonga
Posted on: 2005/12/13 15:21
trust me 45 are way toooooo big, a fully modified 2L runs 45's. rather put in a set of 40's with, i'd say 34mm chokes and then jet it. Nicholas it all depends on the jetting and choking. There are plenty of A12's that run 45's very successfully and there are plenty of 2.0 litres that run 40's. What damage do you think he is going to do to his engine?
#5
nicholas
Posted on: 2005/12/13 11:22
if you put the 45's on you will damage your engine!!! what part of durbs are you from?
#4
Widget
Posted on: 2005/12/13 8:13
kewl man
what sort of cam will i need t put in and what work done on the head? The motor has been overhauled so it has a slightly bigger bore, the head also overhauled but to standard specs. on kina a budget ryt now so cant go over bord (but i wud seriously luv t :D) ...mayb at the end of next year...
#3
matbighat
Posted on: 2005/12/13 6:29
40mm side-eez might be better, but you'd still need cam, extractors and some head work to make use of 'em.
better to stick with weber dgv or twin hitachis for a stocker
#2
teretonga
Posted on: 2005/12/12 16:53
No you will not damage anything in your engine by running the 45's - except maybe suffering oil wash off the bores due to the sheer volume of gas that your motor wil be trying to burn. You do need to understand than unless the 45's are choked and jetted for your motor that they will probably cause it to run very rich. A cam, headwork, branches and the right set up sidies will see you grinning.
#1
Side'es on an A14
Widget
Posted on: 2005/12/12 13:49
Finally got a hold of a side draf manifold. If I put in onto my stock A14 with a set of 45s will i damage anything internally on the engine?? ...or will i need t do some mods 1st before i put it on?
