Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#4
Re: twin carb setup gains?
sidedraught
Posted on: 2006/3/8 7:57
They sell on this site pretty often, a pair of twin Hitachis with manifold will set you back about $150, twin webers with manifold would be more like $500.
These prices are in Aussie dollars and you may pay up to twice as much depending on your luck. Ebay or swap meets are also good places to look.
#3
casper17000
Posted on: 2006/3/8 7:11
what does a setup like this run($$)? where can i get one?
#2
dattodude
Posted on: 2006/3/8 7:03
As far as performance adders, carbies are like turbos...the benefit gained is equal to the engine's potential.
With the right cam, more airflow is required. More airflow means more air/petrol which means bigger carb is required. Twin SUs/webers/solex/dellortos can generally gain 10-20% more power over a stock carby on a standard engine. It's not all fun, twin carbies need to be kept matched and in-tune. This is something that needs to be checked a couple of times per year. Multipoint EFI has all the benefits of 1 carby throat per cylinder, but with none of the drawbacks..except expense maybe ![]() Chris
#1
casper17000
Posted on: 2006/3/8 6:13
