#10 Re: Manifold Flange Cad Files??
casper17000 Posted on: 2006/3/13 5:13
i didn't use auto cad or autodesk inventor because i couldn't find my run disks. i used this program i downloaded in less than 5min from E- machine shop
]it is a pretty easy program. the company will even build the part if you want.
#9 Re: Manifold Flange Cad Files??
mad120y Posted on: 2006/3/13 1:59
I know this might be a stupid question but what program opens ems files?
I have a couple of CAD style programs none can open it.
#8 Re: Manifold Flange Cad Files??
1200rallycar Posted on: 2006/3/13 1:40
i wouldnt mind it also please.... tickfordcortina@yahoo.com
thanks mate!
#7 Re: Manifold Flange Cad Files??
casper17000 Posted on: 2006/3/13 1:06
i sent it to you.
#6 Re: Manifold Flange Cad Files??
TnPshow Posted on: 2006/3/13 0:28
Casper, can you send it to me? Cheers!
Email button below \/
#5 Re: Manifold Flange Cad Files??
casper17000 Posted on: 2006/3/12 12:23
i have a 3d cad file of a manifold gasket shape if you need it i can send it to you
#4 Re: Manifold Flange Cad Files??
andos Posted on: 2006/3/9 8:47
Thanks guys....l have no problem doing it myself. Just wondering if someone already has them, and they know fit properly ?????
#3 Re: Manifold Flange Cad Files??
myti4 Posted on: 2006/3/9 1:39
That is how I would do it scan the gasket in with some measurements on it so you can scale the picture to the correct size and then you can trace around the outside, would only take 5 or ten minutes to do it. I do it all the time with old house plans etc that are in imperial dimensions
#2 Re: Manifold Flange Cad Files??
stirlingmac Posted on: 2006/3/9 0:11
Can't you scan a plot into CAD? ie draw around a gasket scan it and add it as a file?
#1 Manifold Flange Cad Files??
andos Posted on: 2006/3/8 21:39
Hey, just wondering if anyone has cad files they have used to make flanges for inlet and exhaust manifolds (oval port A14).
Would make it easier for me to get them laser cut (rather than having to draw them up).
If you do, let me know. Most formats ok, but l guess autocad is preferred by most laser cutters.
