Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: Fuel Leaks After Each Fill Up
1200coupe
Posted on: 2006/4/24 14:03
Most common leaks occure in the rubber hose that runs from the filler cap to the tank. They go hard and crack over time and slowly leak.
#4
B210guy
Posted on: 2006/4/24 6:16
you may want to take a look at the hoses going to the tubes that run the length of the car, as they crack sometimes. usually above the tank,(if under the car) or under the tank(if inside). if the fuel leaked the whole way home, chances are it's not the vent tube... hope this helps!
#3
Cable_Tie
Posted on: 2006/4/24 6:05
On the inside of the tray there is an access panel behind the fuel filler. Take it off. Have a look. I suspect the overflow has perished or fallen off.
#2
Tyrie
Posted on: 2006/4/24 4:32
its pretty normal for the gun to spill a bit, possibly the seal on your fuel cap is buggered. Also if you overfill the tank the fuel can heat up and expand, flowing out and down the side of your car, damaging the paint
#1
2SLO
Posted on: 2006/4/24 4:14
Hey guys, when i fill my 1200 up i remove the the petrol gun wateva it is after the 1st click but i always notice fuel dripping out from underneath..The other day when i filled it up it was dripping the entire way home.. why is it doing this and how can i fix the problem..
