Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: SQUEEZING OUT EXTRA POWER
120fly
Posted on: 2006/5/2 12:14
Try the msd blaster2 coil its quit good quit a noticable up grade even with points .the good thing is this coil will work with the electronic diizzy as well if you choose too
#6
2QK4U
Posted on: 2006/5/2 11:14
hey tommy - check out datrats.com.au i think thats ferals products, check out the A series parts and they are there - i dont think much is invovled fitting them, we could prob do it ourselves. (i like your ute btw! My utes my first car too)
#5
Tommy
Posted on: 2006/5/2 10:09
i to have been very interested in this electronic ignition, can somebody shed some light on these questions:
WHERE DO I GET THIS FROM??? WATS INVOLVED IN FITTING: HOW MUCH WILL I BE PAYING AND WAT DO I ACTUALLY NEED 2 ASK THE SHOP 4? cheers
#4
B210guy
Posted on: 2006/5/2 3:42
Ihave used a Pertronix electronic ignition, it's less than a hundred dollars (USD) and you'll never change points again. well worth the money, and uses a standard 3 ohm coil. as for perfomance, not a noticable gain, unless pionts were worn, but consistant at higher RPM's ( no point bounce )
#3
2QK4U
Posted on: 2006/5/2 2:28
yeah electronic ignition - can you tell me more please, does the engine perform better? is it worth the $400-500 if my coil set up works well?
#2
sidedraught
Posted on: 2006/5/2 0:33
Whilst the original Hitachis are not the setup for "optimal power",
they will help maintain driveability. Electronic ignition is a good upgrade that you wont regret.
#1
PITBULL
Posted on: 2006/5/1 19:03
I'M PLANNING TO OVERHAUL THE ENGINE ON MY 1200 GX (A12)
I REALLY WOULD LIKE TO MAKE THIS ENGINE PERFORM AS STRONG AS POSSIBLE.DONT WANT A BIGGER ENGINE JUST A WELL TUNED 1200 , I ALSO WANT TO RETAIN THE ORIGINAL SU CARB SETUP. I AM THINKING OF HAVING THE HEAD PROPERLY GASFLOWED, WITH EXTRACTORS TO SUIT WITH 2" FREEFLOW EXHAUST.AND I PRESUME A REASONABLE CAMSHAFT UPGRADE. MY QUESTIONS ARE: 1) - IS THIS SETUP OPTIMAL FOR MAXIMUM POWER . 2) - TO WHAT DEGREE SHOULD THE CAM BE CUT TO MAKE IT PERFORM WELL BUT STILL MAINTAIN ENOUGH LOW DOWN TORQUE TO DRIVE EASY. 3) - IS THERE ANYTHING ELSE WORTHWILE TO DO LIKE UPGRADING THE COIL ETC. I REALLY DO APPRECIATE YOU GUYS COMMENTS AND SUGGESTIONS. THANKS PITBULL PS! I'M NOT SHOUTING, I JUST PREFER TYPING (EXTREMELY SLOW) IN CAPITAL LETTERS You can view topic.
