Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: temp&fuel gauges
moridat
Posted on: 2006/5/16 12:45
have solved half the problem.... connecter from back of car, tank, tail lights etc was not pushed right in BUT the termp gauge still does not work
#4
B210sleeper
Posted on: 2006/5/15 22:27
sometimes capaitors go bad too and make the speedo bounce at certain speeds.
Check the voltage regulator.
#3
B210guy
Posted on: 2006/5/15 21:33
9 out of 10 times it's the "dash voltage regulator" a small device usually on the back of the gauge cluster, now if it is only one gauge, perhaps bad ground, or sending unit,
but if both gauges are not working , then the regulator.
#2
anb008
Posted on: 2006/5/15 14:18
I had a very similar problem on my 120Y... It turned out to be the ground wire on the combination plug being a bit 'iffy'. $10 with an electrician and the this was perfect again. Hope this helps !
#1
temp&fuel gauges
moridat
Posted on: 2006/5/15 13:59
hi
has any one have any ideas why the temp and fuel gauges won,t work on a 1200 coupe i have put in a new temp sender every thing else works fine . also i have a gregorys 1200 workshop manual, which wiring diagram is the correct one to use,the B110 does not have a tacho , the NORTH AMERICAN one has tacho but also has a warning buzzer of some kind very confusing any ideas on problem much appreciated thanks You can view topic.
