Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#2
Re: conversion time
dazzasute
Posted on: 2006/6/27 17:26
something really needs to be put into the tech section on this... it gets asked nearly every week... Here's what i've collected from various sources.
Modified Engine cross member. $200 New gearbox cross member - Need to cut the old mounts out. $50. ->$0 Modify the transmission tunnell - I used a scissor jack then cut & welded to suit the CA18 box. Material.... Say $20. ->$0 Disc brake front end conversion - I went for SR20 disc's on 120Y springs. $450. New battery box mount - Need to cut the existing engine bay battery mount out. Space! Material & welding rods... Approx. $30. Diff conversion - I went for a R31 Skyline LSD, but just about anything will fit with engineering. $180 from wreckers + $500 to shorten + $500 to rebuild. Alternatively - You can use the stock diff, but you'll have to nurse it with the CA. Tailshaft - Stanza 1 peice are easiest. They need shortening, but have the right bolt pattern. $45 from wreckers + $400 to cut & turn. Fuel Tank - You will either need a surge tank on the existing datto item which is a bit small, or an integrated fuel tank / surge tank. I used a R31 item..... Fits like it was made for it - You mount this behind the rear axle & the empty space where you remove the stock tank is ideal for a battery mount. $60 from wreckers + $80 for RHS & bolts to mount. Hydraulic clutch conversion - Use Pintara hyd. clutch ass'y & mount to the firewall. $40. Extended fuel tank filler & wiring - Roughly $150. Radiator - I used an SR20 item. $120 from wreckers. Intercooler - You can just a 65mm item sandwiched in between the radiator & the grill. $600 - $1000. ->$200, bought Intercooler plumbing - Looking at roughly $200. Exhaust - Looking at roughly $1000. Engine + Gearbox - Depending on availability & condition you can expect to spend between $2000 & $4000 - Make sure you get the computer & pollution gear + all other bits & peices. Wheels & tyres - I used 14" skyline steelies & got out of it for $450, but you could easy spend $3 - $4K of flashy 15 inchers. ->second hand etc. $500-$1000 plus rubber Speedo / Tacho conversion - I'm using a refurbished 1200 dash with Autometer guages $350. -> custom, gauges ~$220 Total = $9405 O.K so that's rough costs for changes you'll NEED to make..... As someone else stated, some of these parts are getting harder to find so more $$$. Of course this pricing doesn't included labour.... I'm lucky that I can do it all myself. I shudder to think if I had to pay someone. Haven't included paint & panel costs. Hope this helps. Cheers, Coops D A T T O: did my CA conversion in my 1600 for under $3500 Engine box, loom, ecu. $1100 - private seller. conversion kit - $770 - stewart wilkins exhaust - $750 - Kirrawee mufflers full 3 inch no cat cooler and piping - $260- just jap for the cooler and silicone bends - exhaust shop for pipe. surge tank and pump - $200 tanks from stewart wilkins, pump from private seller. thermo fan - $120 - auto one menai. boost guage - $30 repco turbo timer - $50 just jap
#1
conversion time
fat_dat
Posted on: 2006/6/27 14:46
ok 1200 fans. i've decided to start a conversion, not into my ute but into a sedan i'm about to buy. if someone could PLEASE jot down a check list of everything that needs to be done (not price list etc) to wack the CA in. It's already got the auto trans tunnel so don't include that. cheers.
