#12 Re: Is the ca18 really the best engine for a datsun 210???
Gary_P Posted on: 2006/7/14 2:19
Personally, I think the choice of what engine to swap in comes down to your choices of what compromises you want to choose.
Like any project, there is no "best" way. Any project is nothing more than a selection of compromises. You need to decide what you want the car to be when done, then choose the compromises that get closest to your goal.
As my interest is autocross if I go beyond the current A15 project for power, I'm leaning towards the CA18DE. Handling is the most important measure to me followed by engine response. Turbo lag and adding weight to the front of the car are not compromises I'm interested in.
If you are more into straight line speed then the heavier engines may be what turns your crank.
Gary
#11 Re: Is the ca18 really the best engine for a datsun 210???
dattodude Posted on: 2006/7/14 1:04
Seems the webserver system time has changed. I can't reply to this thread in chronological order... Hmmm
#10 Re: Is the ca18 really the best engine for a datsun 210???
dattodude Posted on: 2006/7/14 0:53
Yes a little of course, but you can get performance parts and spares without selling your unborn babies.
You get more power, better fuel economy and improve the environment from lower emissions.
When battery technology improves, I'll be happy to go to full electric. The visible end to supplies of fossil fuel does not worry me these days.
#9 Re: Is the ca18 really the best engine for a datsun 210???
L18_B110 Posted on: 2006/7/13 23:46
B210sleeper wrote:
So the KA and SR aren't going to kill the handling?
not necessarily...
Adam Allan's SR20 1200 race car
#8 Re: Is the ca18 really the best engine for a datsun 210???
B210sleeper Posted on: 2006/7/14 3:22
#7 Re: Is the ca18 really the best engine for a datsun 210???
matbighat Posted on: 2006/7/14 2:11
i think you mean best engine swap? as was explained above, the ca18det is more common in oz, and there's also the displacement regulations in some areas. you'd be better off with an sr20 or even a ka24 if you're on a budget
#6 Re: Is the ca18 really the best engine for a datsun 210???
Duncan Posted on: 2006/7/14 1:12
Has anyone seen a Rover / Buick V8 in a Datto? I have seen a few smallblock Ford's in 510's, and a LOT of smallblock Chevy's into the Z's, but not too many V8's in other models.
#5 Re: Is the ca18 really the best engine for a datsun 210???
B210sleeper Posted on: 2006/7/13 23:30
the biggest problem seems to be the weight of these powerful engines, SR's, FJ, KA engines are all so heavy.
#4 Re: Is the ca18 really the best engine for a datsun 210???
matty Posted on: 2006/7/13 14:17
One of the main reasons for the popularity of the CA conversion is that the motors are plentiful and reasonably cheap in comparison to the SR. FJ's are getting pretty scarce nowadays. CA's are also more compact and lighter than the other 2 motors you have mentioned. Also crossmembers, wiring looms etc are available with a few clicks of your mouse.
The SR is a newer motor and consequently has better aftermarket support but is still quite expensive to purchase.
Regards Matty
#3 Re: Is the ca18 really the best engine for a datsun 210???
sunny1046 Posted on: 2006/7/13 14:09
ca18s are kool but why not try an sr20det or fj20det...they seem like ok engines in my opinion....full of power and very tunable.
