Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: Drums Brake shoes Adjuster stuck
Razor
Posted on: 2006/7/23 6:33
thanks for the reply will try and if I cant get it to budge I'll get new ones.
Cheers
#6
PIGDOG
Posted on: 2006/7/23 2:15
i just pulled mine out and wound the adjuster all the way back, so it isnt touching the little metal things that push on the shoes
then i just tapped the metal things back into the adjuster, this and alot of inox was enough to free them up then you wind the adjuster all the way out so that the metal things come out, then clean them up with some sandpaper and also clean the thread of the adjuster then they should be as good as new
#5
who_your_datty_1200
Posted on: 2006/7/22 23:29
When I did the rears on Monty, I replaced my adjusters with new ones. Sounds like you would need to rekit them if they are stuck, but goto a good brake place with one of them and see if they can get you new ones??? If they are anything like 620's I can get new ones.
#4
datracer
Posted on: 2006/7/22 20:18
Try heating the aluminum body with a propane torch after using a good penatrating oil. Make sure you have the adjuster secured in a vice. Good luck Larry.
#3
Posted on: 2006/7/22 18:00
I have the same problem with my B110. Even in the vice I cannot get it to turn.
Do B210 or B310 adjusters interchange?
#2
Tham
Posted on: 2006/7/22 16:29
Hunting's of England had a couple of good
lubricant sprays for loosening rusted parts and freeing locks, they were called Ezy-Open or something, and are better than the usual WD40 or RP7. Possibly you could try those.
#1
Razor
Posted on: 2006/7/21 11:32
Hi
I was trying to adjust my brake shoes adjuster on my drums and it seems to be stuck, wont budge at all even after removing the drums and tried tapping/hitting it. Anyone got advice on tackling this issue? You can view topic.
