(1) 2 3 »
#21 Re: 1200 body mods
andos Posted on: 2006/8/20 12:23
I'm a fan of the smooth look.........
Mines got smooth door handles & locks, B pillar plastic vents removed and inner smoothed over, rear rain gutter and rail on tub removed, tail lights smoothed over, custom rear tailgate section weleded and smoothed, aerial removed and welded over, bonnet squirters removed, fuel filler relocated inside tray, rear cabin wall smoothed over on outside (under rear screen)......
think thats it......well you can check out my pics in the photo album anyway......
Cheers
Andy
#20 Re: 1200 body mods
datto_lowrider93 Posted on: 2006/8/20 12:04
well i think ill take off my vents behind windows ,rear bumpers and handles on tailgate and weld up were they were make it look real tidy like yours ___1200ute cheers m8
#19 Re: 1200 body mods
___1200ute Posted on: 2006/8/20 11:58
Thanks datto_lowrider93, its a fair way of being finished and some areas are still looking a bit dodgy, but i'm pretty happy with what you can see in those pics.
#18 Re: 1200 body mods
Turboute Posted on: 2006/8/20 6:21
Mines the same tank but with a longer hose and gets filled through the tray.
#17 Re: 1200 body mods
dat5_al Posted on: 2006/8/20 6:17
a bit of a noob here but when people say they shave the fuel filler cap do they get a whole new fuel tank and fill it else were or wat
#16 Re: 1200 body mods
datto_lowrider93 Posted on: 2006/8/20 4:34
thanks ___1200ute ur ute looks great
#15 Re: 1200 body mods
carjunkie Posted on: 2006/8/20 2:56
Hey, can i have those bit that you want to take off your ute. I want to put them back on the ute ive got. Tell me if we can do a deal.
#14 Re: 1200 body mods
___1200ute Posted on: 2006/8/20 1:45
I welded up the fuel filler, those vents behind the doors, got rid of the body seams, removed the rear rubber bumpers, got rid of the tailgate handles and hinges and removed the rain gutter around the doors and the tray including the tie down hooks
mods1
mods
#13 Re: 1200 body mods
Dodgeman Posted on: 2006/8/20 1:18
oan878 wrote:
does it fog up more if you seal the cabin?
If you are in 'high fog' conditions with the fan turned off & the air intake turned to 'recirculate' [no fresh air coming in] then I have found that the screen fogs up with the speed of light. This is with no airflow across the screen.
Select 'fresh' air & blow it across the screen with a little heat added & the screen will clear. If you add aircon, it clears much faster, so I guess that the answer to your question would be 'Yes'
My 1000 sedan had an original defogger for the back window. It was a horizontal blower that simply blew air on the glass & it worked a treat. When the heater kicked in & some warm air was available to it, then it worked even better, so air movement across the glass is a must for fog clearing.
If the original outlet vents are sealed, & an alternative outlet is provided, then it should all be good, so long as the air can flow.
Of course, if the outlet vents are sealed & the car is parked in the sun, then any pressure rise from expanding air is simply vented through the intake side of the vent system, & even if this was sealed, it would bleed past the edge of the door glass via the woven material in the bailey channel, so windscreens would be safe.
#12 Re: 1200 body mods
Turboute Posted on: 2006/8/20 0:58
Thanks go the utes.
(1) 2 3 »
