Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: Gasket Goo Question
matty
Posted on: 2007/4/7 20:37
Thanks again for the answers guys. I thought I'd start on it this afternoon and once I got all of the plumbing out of the way I found it was just a couple of loose bolts. Very happy!
#6
matty
Posted on: 2007/4/6 23:13
Thanks for the responses guys. Hopefully it will make it through next Saturday and I've then got a month to fix it before the next sprint meet.
Happy Easter Matty
#5
Steveo_1987
Posted on: 2007/4/6 13:46
Yer dodgeman and blofly have got it right. Your better off fixing it properly by pulling all the gear out. Chuck a sickie from work and spend a day on it. As blofly said do the job right and you won't have to worry about it for sometime.
#4
blofly
Posted on: 2007/4/6 4:02
I am afraid dodgeman is right.
There is no chance of repairing a leak from the outside in while pressure is forcing its way inside out, like trying to hold your hands around a leaky waterpipe under pressure, you get wet sounds like you have a big days work but think of it as a good chance to do the job right
#3
matty
Posted on: 2007/4/6 0:45
Hi Dodgeman
Are you saying put muffler putty in between the flange faces? Because I can't separate the manifold and the turbo easily. If it comes to that I may as well pull everything out and replace the gasket all together. To do this I need to remove the intake piping, intercooler piping, oil catch can, dump pipe, oil and coolant lines to the turbo etc. It's a whole day job unfortunately. The joys of a big engine in a little engine bay........ Is there any solution I can use for next weekend? Anyone?
#2
Dodgeman
Posted on: 2007/4/6 0:00
Not around the sides, as this will just blow out, but sometimes muffler putty when used as a gasket sealant works well enough.
#1
Gasket Goo Question
matty
Posted on: 2007/4/5 23:44
The gasket between the exhaust manifold and the turbo has started to leak on my CA. As it's a large job to fix and I don't have time before my next track meet is there any type of gasket goo that I could put around the sides where the flanges meet to stop the leak? Is there a product that will handle the heat?
Cheers Matty You can view topic.
