#8 Re: Parts for sale
dattoman_1000 Posted on: 2007/5/11 15:06
Carbs/manifold gone
Cam gear gone
Cam gone
Clutch plate spoken for pending payment
Rest still avail
#7 Re: Parts for sale
dattoman_1000 Posted on: 2007/5/8 22:27
When you come over I'll show you
#6 Re: Parts for sale
kue1000 Posted on: 2007/5/8 21:50
I love the look of that cast rocker cover - would it work cutting a hole in it to use on a non drysump?
#5 Re: Parts for sale
dattoman_1000 Posted on: 2007/5/8 19:18
Carbs, cam, camgear and clutchplate spoken for pending folding pineapple coloured beer tokens appearing in my wallet
All rest still avail
#4 Re: Parts for sale
kue1000 Posted on: 2007/5/8 18:57
PM sent
Here goes this months spending money
WEEEEEEEEEeeeeeeeeeeeeeeeeeeeeeeee!
Yup it's gone!
#3 Re: Parts for sale
1200rallycar Posted on: 2007/5/8 18:54
will definately grab the clutch plate off you.... will organise through PM, will send one later today
#2 Re: Parts for sale
benny Posted on: 2007/5/8 18:52
free bump
#1 Parts for sale
dattoman_1000 Posted on: 2007/5/8 18:34
Due to the sale of my racecar I have some stuff superfluous to my needs so its up for sale
Some I have advertised before but here we go again
Pair of 40 DCOE webers on oval port Redline manifold suit A series.
Webers are marked 40DCOE31 Serial numbers 18943 and 16479
36mm chokes I think. Might be 32.Haven't actually measured. Look like 36 visually though.
Jets and tubes as follows. If you know about webers you will know what these mean. I don't
45 F9
200 inner F15 125 bottom
Manifold is centre bolt between inlet ports. So if you don't have this hole you will need to drill and tap 8x1.25 to take the cap screw provided.
They have full linkages and fuel inlets on them. This is them before fitting to racecar
http://members.iinet.net.au/~dattoman_1000/images/carbs.jpg
http://members.iinet.net.au/~dattoman_1000/images/carb.jpg
They also come with 4 finer filter socks and about half a bottle of recharge oil to redo them before they go onto a new car.
These worked very well on my A15 racecar. If anything they ran rich. I made 100hp atw so I'd say they are big enough for any road or race A series.
$1000
A Series Cast alloy Dry sump oil pan I shipped out of USA .
$250
A series Rocker cover cast alloy to suit dry sump system (no oil fill hole) also from same US company
$120
Peterson 5 gallon dry sump oil tank with heaters. Damaged top mount (repairable) some small dents. Was in sprintcar in USA
$200
Camshaft Engineering cam
Grind 2513, 220 thou lift at lobe. 296 deg duration
inlet opens 40 deg before TDC closes 76 deg after BDC
exhaust opens 40 deg before BDC closes 76 deg after TDC
$50
Multidrilled A series Camgear purchased off another forum member here and never used. I bought a Feral fully adjustable one so have no need of the multidrilled one
$20
Pair of 1000 front doors. Good nick complete doors
Look good to me but don't fit any of my vehicles
I believe them to be 4 door sedan ones
Length of door down the centre hip line is 850mm.
Worth a look.... too heavy to ship so locals only preffered.
$75 each
R7514W clutch plate for use with Celica box with Dellow conversion to A series. I use a Toyota clutch so had no need for this one
$20
N14 Pulsar 2.0 (SR20) clutch kit to suit 6mm dowels. Basic street clutch (nothing fancy) Velo plate inc bearing.
$70 ono
Prices are of course plus shipping if required
I don't work for the post office so if you need prices for shipping give me time to find out
Pics are available on request.
PM me here or add to this thread and I'll be intouch. Or call during WA work hours on 08 9390 0183 or after hours I might answer on 0408 597751
Cheers
Neil
