Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#9
Re: why do you need an internal and external fuel pump?
onetwo00
Posted on: 2007/6/30 15:03
was the car ever fitted with a surge tank?????
my a14 turbo fuel inj just runs a single VL fuel pump. had to waste a good stubbie holder too trying to keep the thing quiet....
#8
Dodgeman
Posted on: 2007/6/26 16:47
Some run a low pressure pump to provide VOLUME to the remotely located surge tank [when fitted] & a higher pressure pump that is located in the swirl pot/surge tank to supply the EFI system, while others simply run a single low or high pressure pump as the occasion demands.
#7
Posted on: 2007/6/26 16:38
why do you need an internal and external fuel pump? - backup - for racing with surge tank as described by BigD
#6
BigD
Posted on: 2007/6/26 12:55
Well im not 100% sure about internal and external fuel pump i thought it was based on your fuel tank. As all EFI cars have one or the other. What im running is a lifter pump, like something that you would use on a webber engine. This fills up my surge tank, then a high pressure efi pump feeds the engine via a fuel pressure regulator. I am also running larger fuel line.
Im sure you all know what im talking about espically anyone with a surge tank.
#5
120fly
Posted on: 2007/6/26 10:55
I used a carter fuel pump about the size of a matcbox car about 65$ from your local speed shop or autopro .they have enough flow to keep the fuel there when on boost but not enough pressure to blow the needle and seat open in the carby open .which is good way to go saved running a pressure reg .when my car came on boosts you could hear the fuel pump speed up and when you slowed down you can hear the pump slow down....
#4
LittleFireyOne
Posted on: 2007/6/26 10:38
mabey one is supposed to assist with the fuel return to the tank
#3
frankthedolphintrainer
Posted on: 2007/6/26 10:35
turboed a12 (small turbo)
#2
LittleFireyOne
Posted on: 2007/6/26 10:34
???? what for, efi applications or something?
#1
Posted on: 2007/6/26 10:30
yep as the title says or could you just use an external
