#5 Re: need advice please
sooty_grunter Posted on: 2007/8/3 23:03
you dont NEED a different g/b im runnin a ca box, you just gotta take the gear stick out and turn it round takes 5 mins, the stick leans fwd and is in the perfect position.
#4 Re: need advice please
mrtubbs Posted on: 2007/8/3 22:17
sounds like good advise mate thanks for your help
#3 Re: need advice please
A14force Posted on: 2007/8/3 21:22
this conversion although not impossible is not too easy. make sure you start with a motor from a rear wheel drive car.
#2 Re: need advice please
dattodude Posted on: 2007/8/3 21:15
1. talk to an engineer. Many won't pass it, that's why so many 1200 owners in Australia use the CA18det.
2. Because the utes have a small cabin, you'll need to get shorter gearbox than the S13/14/15 one. R30 Stumpy Skyline or rb20 import skyline box (both need bellhousing swap.
Everything else has been discussed to death on this website.
#1 need advice please
mrtubbs Posted on: 2007/8/3 21:11
need some help please guys,my brother has a 1980 model dato 1200 ute and wants to put a sr20 turbo in it i am more than capable of doing the conversion but thought id ask you guys which box to use ,bellhousing,exhaust,brake booster ectseems like its a common conversion so any advice or help would be much appreciated
