#12 Re: l series vs ute diff???
Trav Posted on: 2007/11/9 4:51
Ok sweet thanks ange. Like i said a while off yet but just getting ideas. Will definately go the ute diff though.
And big D if ange is right i guess you are gonna have some problems then if you do that swap you were talking about and do what you are planning to do
Pm sent about that to D.
Cheers
Trav
#11 Re: l series vs ute diff???
ANGE Posted on: 2007/11/9 4:39
in my ute i originaly used a cut down auto stanza tailshaft which mated my 12a rotary engine to the stock ute diff.
had it like that for about 6 months and the diff and stanza uni never looked like breaking. the diff still lives on now with an lsd in boofheads sedan.
you'll only run into problems with the ute diff if you lock it.
good luck
#10 Re: l series vs ute diff???
BigD Posted on: 2007/11/9 4:33
Dont be to fussed with the Tailshaft Trav, you use two tail shafts. one with the yoke for your box and one with the flange to bolt to the diff then they get shortened and balanced. i have a contact for when you get to that stage.
#9 Re: l series vs ute diff???
Trav Posted on: 2007/11/8 23:54
Cool thanks ange, i think i will go that way. I will just have to be patient with the lsd i guess and try and snap one up somewhere.
Stick with what i know......you know.
Cheers
Trav
#8 Re: l series vs ute diff???
ANGE Posted on: 2007/11/8 7:11
i would use h165 it should be fine.
lsd's are expensive though
you can also use a stanza tailshaft to cut down.
#7 Re: l series vs ute diff???
Tyrie Posted on: 2007/11/8 7:06
s3 bluebirds had a h190. My 2.6L sigma had the same borgwarner diff as 120Ys.
#6 Re: l series vs ute diff???
spenc Posted on: 2007/11/8 6:20
i thought the bluebirds had a h190 or something like that
#5 Re: l series vs ute diff???
Trav Posted on: 2007/11/8 6:11
Are the BW diffs easy enough to find though?
Also what tailshaft is needed for this conversion? Will the trx tailshaft be compatable?
Thanks
Trav
#4 Re: l series vs ute diff???
L18_B110 Posted on: 2007/11/8 5:41
a 120Y BW will be alot cheaper. They're the same width as the 1200 diff. These diffs were also used in lots of different 2L cars.
#3 Re: l series vs ute diff???
Trav Posted on: 2007/11/8 5:14
Ok thanks tyrie.... i wasn't aware of that.
So the bluebird tailshaft should also fit up with the trx 5 speed box? Shortened of course.
Thanks
Trav
