#5 Re: vanette 1500
A14force Posted on: 2007/12/6 8:43
Some vannettes have a different style thermostat housing. (Same as a cherry) But otherwise they fully same as the cars.
#4 Re: vanette 1500
frankthedolphintrainer Posted on: 2007/12/6 8:26
and obveously you will need a gearbox aswell as the vanettes are column shift
#3 Re: vanette 1500
dartson Posted on: 2007/12/6 8:18
Is there any differance in the heads , i heard somewhere that there is some difference
cheers
#2 Re: vanette 1500
A14force Posted on: 2007/12/6 7:30
I think that the water neck that feed the bottom hose of the radiator is longer. Other that that there is no diference. You will need to bolt on the car engine mount brackets though.
#1 vanette 1500
dartson Posted on: 2007/12/6 1:18
is there any differance between a vanette 1500 and one say out of a sunny etc .
cheers
