#5 Re: fitting 1200 motor into 1000 ute
dats1000 Posted on: 2007/12/20 4:06
baldy wrote:
I had a 1200 in a 1000 centre distributer now run a 1400 all you need to do is a little mod to the engine mount not a big job I can send you a picture of them if you like
thx baldy pic would be great if u could mail it to iian1@hotmail.com
thank you all for your help
#4 Re: fitting 1200 motor into 1000 ute
baldy Posted on: 2007/12/19 8:52
#3 Re: fitting 1200 motor into 1000 ute
Cable_Tie Posted on: 2007/12/19 4:16
The one with the distributor at the front is what you are after.
If you have a welder, either will do. . .
#2 Re: fitting 1200 motor into 1000 ute
frankthedolphintrainer Posted on: 2007/12/19 4:10
there are two types of a12 im pretty sure you need the earlier type
#1 fitting 1200 motor into 1000 ute
dats1000 Posted on: 2007/12/19 4:05
do all 1200 motrs fit into a 1000 i have one but friend told me they wont all fit any help would be good does engine numbers help
