Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#4
Re: brake dramas
B210sleeper
Posted on: 2008/1/7 15:00
the brakes that big it needs a 15"
Watch the weight of the wheels and tires, trying to keep the same outer diameter is a good idea. Tires wider than 195 seem like a bad idea unless you like having a really hard time while moving slow.
#3
Re: brake dramas
PIGDOG
Posted on: 2008/1/7 10:22
or nissan, mitsbishi, some mazda even toyota i think
i know magnas have 15 inch chaser like wheels with a fwd offset or just try the many different offsets that come with falcon stockies depending on the model
#2
Re: brake dramas
Tyrie
Posted on: 2008/1/5 6:03
Falcon wheels are pretty much your only option I would have thought...
You should be able to get the offsets changed on a pursuit wheel, might cost a few hundred $$ though.
#1
brake dramas
SLUG1200
Posted on: 2008/1/5 5:59
hey guys
i purchased a hoppers stoppers kit to suit a datto ute with stanza struts... brakes r fricken huge hey... commodore disks with ford au callipers drilled and slotted... definately look the part.... but wat a mission to put in... the instructions make it sound so easy..... the end result is that i hadto switch around the front struts (its the only way i could get it to work). now i have the fun job of picking out the right wheels with the right offset.... i have changed the front to a ford stud pattern to match up with the hilux diff stud pattern.... if anyone can make a suggestion on what wheels off what car will fit mine, it would be very muich appreciated..... hasto be no smaller than a 15 and hasto be a persuit rim... cheers You can view topic.
