#2 Re: Ebay CA18DET stainless steel manifolds... rubbish?
kegs Posted on: 2008/3/27 10:22
theres a cheap #### manfiold and a cheap not bad one i got one 250 show polished 3.2mm thick cant fault it if its high mount brace it to the brace but shouldnt need it just brace the runners to the manifold plates the manfiold cant be braced it needs flex and will have massive amounts when stainless is hot. just keep an eye out theres a place called n power on ebay their ones are mad might be able to get high mount
#1 Ebay CA18DET stainless steel manifolds... rubbish?
Poco Posted on: 2008/3/27 10:14
Hi all im running a GT28/30 turbo on what suspiciously looks like an ebay special el cheapo high mount turbo manifold.
It was fitted by the PO and the welds began to crack in the manifold a few months after i bouught the 1200, i had them welded up but a couple months later they have cracked again.
Has anyone else had problems with ebay manifolds? Im tempted to try my luck depending on others experiences... but im thinking the weight of the turbo could be the main reason the welds cracked.
Should i just save my beans and go full custom with bracing or try my luck with an ebay manifold and get some custom bracing made up to take some of the weight off it?
Cheers!
