Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: Modifying an electronic dizzy??
Dodgeman
Posted on: 2008/4/5 16:06
No place to plug it onto. Generally, small engines with dual Webers will have a hot cam as well, & the net result is a vacuum signal so weak that it wouldn't suck fizzy drink up a straw, so even if you could connect it, it would remain non functional anyway.
#4
LittleFireyOne
Posted on: 2008/4/5 15:42
the nature of the sidedraft and how it's tuned ussually means the motor is setup for one particular area of the rev range so the flexible timing interfers with taht. There's that and the fact that they don't have a vacume line connector on them
#3
teflon
Posted on: 2008/4/5 11:01
why disconnect advance connector for weber setup? please explain.Thanks.
#2
phunkdoktaspok
Posted on: 2008/4/5 3:19
just leave the hose disconnected and dont touch the dissy internals. simple.
#1
ROConnor
Posted on: 2008/4/5 3:17
When removeing the vacume addvance unit for a weber setup, do you hav to modify the inturnals or just lock up the bit that rotate's?? Thank's!
