Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: CA18 Air Flow Meters ???
matty
Posted on: 2008/4/14 20:46
Perthute - you've definitely been given a bum steer mate. Your ECU needs to be retuned to suit the new AFM and, as the Z32 version uses a different plug, you will need the wiring modified too. This mod is really only required in high boost, bigger turbo scenarios.
As for the AFM model code question I am not sure but these generally cost $20 so it's probably worth buying a couple anyway. Matty
#4
perthute
Posted on: 2008/4/14 12:44
i was told its a bolt on thing but i could have bum steer .
#3
dazza1200
Posted on: 2008/4/14 12:08
only if ecu is calibrated for it
#2
perthute
Posted on: 2008/4/14 10:40
hey man if your gonnna buy one get the z32afm bigger better
#1
old_school
Posted on: 2008/4/14 9:31
Part Number Manufactured
22680-58A00 5/99 to 7/89 22680-58A10 7/89 to 1/91 From research I have found that these were the two air flow meters used in the CA18DET engine. Are they interchangable? I have a faulty 22680-58A00 but can get a 22680-58A10 I would assume they are the same but thought I would ask first ... Cheers You can view topic.
