#6 Re: alt test
revhead001 Posted on: 2008/4/17 14:03
hell yeah. If it's not working then you might as well not have an alternator.
I forget that outboard regs still exist.
#5 Re: alt test
ferg Posted on: 2008/4/17 13:53
Alt has been checked and is good, Could voltage regulator have anything to do with the problem?
#4 Re: alt test
revhead001 Posted on: 2008/4/17 13:44
Most likely because the alternator cannot produce the voltage and amps req to keep it running. It may be draining the battery as you drive.
#3 Re: alt test
ferg Posted on: 2008/4/17 13:41
Any ideas why my engine dies after removing pos cable? all accesories are off!
#2 Re: alt test
revhead001 Posted on: 2008/4/17 13:37
Not if all the accessories are off. Should run quite happily.
#1 alt test
ferg Posted on: 2008/4/17 13:36
Should the engine die after disconnecting the pos battery cable on my 77 b210?
