Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#3
Re: horn wiring diagram for 1200
bailz
Posted on: 2008/11/27 3:27
well most of my wiring is already 2.5mm cause i had 2 rewire a fair bit of it... 2.5mm is pretty much double the usual wiring for it, but i got the wire free so itsno biggie
#2
1200rallycar
Posted on: 2008/11/27 1:57
relay is just so you can run a thinner "trigger" wire back to the horn button, it is not needed. but you may need thicker wire to run to your horn button and back without a relay (not that i can imagine a horn pulls many amps?)
#1
bailz
Posted on: 2008/11/27 1:04
ok, i want 2 get my horn working, the relay has been removed and there is not much wiring i can see...
i chnaged the horn so it doesnt earth through the body of the horn like the old ones so it has a + and a - i know i can just run a positive to the horn and switch the negative but am just wondering whther i need a relay? cheers You can view topic.
