#11 Re: my 1000
casey Posted on: 2009/1/19 3:31
yer thats the one hahaha i will try and make the adelaide cruise on the 31st to meet some of SA's datsun comunity
#10 Re: my 1000
1200rallycar Posted on: 2009/1/18 12:11
haha saw this wagon at datnats in adelaide all those years ago... from memory it was pretty straight back then (at least it was a red wagon with black bonnet with stenciled writting... has to be same car)
good to see it getting fixed up again
#9 Re: my 1000
casey Posted on: 2009/1/18 10:59
just wonderin with the 1200 coup diff centre and it being a different ratio wat is this going to do gear pickup and top speed wise???
#8 Re: my 1000
Dundee1000 Posted on: 2009/1/18 9:06
I think i made Mini ones fit in a few I've done, and 1200 ones for the rear..
#7 Re: my 1000
beattie Posted on: 2009/1/18 9:01
Chances are if you goto a wrecker for shocks... They will be just as soft as your current ones! Get em new! There is a reason people are using Torry shocks and not 1000 ones
#6 Re: my 1000
casey Posted on: 2009/1/18 7:17
received new diff centre from PIGDOG that was put in today also gave it a service and changed the oil and hoses and bleed the brakes the old brake fluid was like gravy when it came out so now going to was my car and should be all shiney to cruise around in for awile now just need to hit up the wreckers for some LJ torana shocks because my front shocks have just about had it. and find an A15 and 4 spd
#5 Re: my 1000
casey Posted on: 2009/1/2 5:14
i would weld it but only as a last resort because i think it would be alot harder to find spare axels for a 1000 in SA than the diff centre
#4 Re: my 1000
perthute Posted on: 2008/12/30 4:39
weld it
#3 Re: my 1000
pepper Posted on: 2008/12/30 4:01
haha 'bitchumen'
what happened to the teeth in there?
#2 Re: my 1000
casey Posted on: 2008/12/30 3:57
finnaly got off my arse today and did sme work i have been busy with christmas at work and my end of year exams i finaly need to get my #### togeathr and put the 1K back on the road i pulled the main proble out today the diff centre i had fun cleaning and colleting teeth so now n the hunt for a new centre to transfer the gears into my housing
