#3 Re: Can A12 GX run with 5 Gear Box ?
ddgonzal Posted on: 2009/1/5 6:17
Yes, A12 GX is just an A12 engine; the block, flywheel and clutch is identical to regular A12 engine. You can use any of the three kinds of 5-speeds that fit.
#2 Re: Can A12 GX run with 5 Gear Box ?
datto1000wagon Posted on: 2009/1/5 5:40
should bolt straight in if its from an a series motor and is floor shift
#1 Can A12 GX run with 5 Gear Box ?
Sumith Posted on: 2009/1/5 5:26
Hi Guys
Can we fix a 5M GearBox to B210 GX (1974- 4M)
Thanks
Regards
Sumith
