#12 Re: WTD..perth..
dazza1200 Posted on: 2009/1/18 8:38
if your just measuring up i have a disc thats u/s that you can have now
dazza
#11 Re: WTD..perth..
Dundee1000 Posted on: 2009/1/17 13:27
spidey might be on the money..
only need solids as the calipers i have in mind are for 10mm disks,
ex aussie spec corolla, lighter than the laser caliper conversion.. but just as simple, if the offset on the 1200 disks is ok..
#10 Re: WTD..perth..
PIGDOG Posted on: 2009/1/17 11:42
75 series rear discs were too hard to find beattie?
#9 Re: WTD..perth..
beattie Posted on: 2009/1/17 11:40
Not another 1000 disk brake convo?
Theres a few combos out there already and when you think about it, its not too hard to find out a setup. I just went through the RDA book and looked at the offsets of rotors and things for a rear disk setup i figured out for my landcruiser
#8 Re: WTD..perth..
steveo Posted on: 2009/1/17 11:38
I think the 1200 hub fits on the 1000 spindles..
do my spidey senses tell me that you may be
doing a disk brake conversion for dato 1000's???
#7 Re: WTD..perth..
ROConnor Posted on: 2009/1/17 11:37
Isent yours allso a 2 door? witch I fairly shour would make it an import, so same rules dont aply!?
Yours are probly the same as coupe one's
#6 Re: WTD..perth..
levey Posted on: 2009/1/17 11:33
my sedan has disc's
#5 Re: WTD..perth..
dazza1200 Posted on: 2009/1/17 9:25
coupe got discs
sedan got drums
ute?
got some 120y stuff maybe
#4 Re: WTD..perth..
Dundee1000 Posted on: 2009/1/17 9:12
thanks dudes,
not sure if the coupe and 1200 sedans are the same,
thats all that fancy pogostick late model stuff..
#3 Re: WTD..perth..
levey Posted on: 2009/1/17 6:15
I have a 1200 disc rotor you can have.
