#14 Re: Fuel Sensor doesn't work ?
Sumith Posted on: 2009/3/9 7:53
Hi ddgonzal
That was the broken connection in the sender wire
Thanks
Regards
Sumith
#13 Re: Fuel Sensor doesn't work ?
ddgonzal Posted on: 2009/3/9 7:45
Glad to hear you got it fixed. So there was a loose wire inside the fuel tank on the sender itself?
#12 Re: Fuel Sensor doesn't work ?
Sumith Posted on: 2009/3/9 7:31
Hi Guys
Got it done by my self ,actually that was a broken wire connection with the sensor
Thanks
Regards
Sumith
#11 Re: Fuel Sensor doesn't work ?
LONGBROW Posted on: 2009/3/6 17:52
Ok ...I got confused whether it was the sending unit or gauge that was bad.
If you have determined it is the sending unit and you cannot get another one; it may be worth your time to remove and clean it. It could easilly be stuck,or the float may no longer float. My car had sat for about 15 years before I bought it and the sending unit was covered in rust and varnish. Cleaned it off and she works like a champ.
#10 Re: Fuel Sensor doesn't work ?
Sumith Posted on: 2009/3/6 5:17
Hi LONGBROW
as ddgonzal said i checked the fuel sensor gauge, as he sais the sensor went to top means bad sensor or loose wire connection
Thanks
Reagrds
sumith
#9 Re: Fuel Sensor doesn't work ?
LONGBROW Posted on: 2009/3/6 4:28
Sunsmith-
What do you mean fuel sensor is gone? Have you removed it and checked the variable resistor?
#8 Re: Fuel Sensor doesn't work ?
ddgonzal Posted on: 2009/3/3 5:57
It is very specific to B210 sedan. Coupe is probably different.
#7 Re: Fuel Sensor doesn't work ?
Sumith Posted on: 2009/3/3 5:51
Hi ddgonzal
As you said I checked my Fuel Sensor it is gone, are those available to buy or can i fit another fuel sensor , is it common or datsun specific sensor ?
Thanks
Regards
Sumith
#6 Re: Fuel Sensor doesn't work ?
ddgonzal Posted on: 2009/2/26 8:27
It is not normally repaired, but instead replaced. I have no experience in trying to fix a bad gauge.
If a wire is broken, you may be able to solder it as a repair.
#5 Re: Fuel Sensor doesn't work ?
Sumith Posted on: 2009/2/26 8:10
Hi ddgonzal
I have done a wiring job recently i could not fix all the dash board gauge, is it possible for me to fix those gauge wiring by my self, i am not a mechanical person , how is it difficult task or easy task ?
Thanks
Regards
Sumith
