#4 Re: mechanical fuel pump
teflon Posted on: 2009/3/13 4:51
Thanks andy, i'm also using a12 pump, just worried if there r problems with that.
#3 Re: mechanical fuel pump
andy-roo Posted on: 2009/3/13 4:41
Im using an a12 fuel pump in my a15 and I don't have any fuel problems
#2 Re: mechanical fuel pump
ddgonzal Posted on: 2009/3/13 3:14
Virtually all the same: around 3 psi and 450 ml/minute minimum flow rate
A12 uses a shorter pump than A14/A15.
#1 mechanical fuel pump
teflon Posted on: 2009/3/12 14:52
hi friends, i just wanna know what's the different between A12, A14 and A15 fuel pump? what's the fuel flow n pressure? thanks.
