#15 Re: urgent help required- Dellow 5-speed problem
dattoman_1000 Posted on: 2009/4/15 18:26
I always thought mine used a modified Datsun carrier and bearing on the modified Toyota spigot.
I recall boring out the carrier and machining down the spigot to use the Datsun carrier and bearing
Can't check though
Am 10 000 miles from the gearbox
#14 Re: urgent help required- Dellow 5-speed problem
sidedraught Posted on: 2009/4/11 11:21
This box had been completely overhauled, and had been working without issue in a competitive race car since the rebuild, I hope you can find the source of the problem.
#13 Re: urgent help required- Dellow 5-speed problem
wards Posted on: 2009/4/11 5:18
stevo you must check that the bellhousing is square to the block and the spigot hole in the bellhousing is concentric to the crankshaft , do this with a dial indicator stuck on the flywheel and turn the motor over by hand , sorry to let the wind out of your sales but i have had some bad results with dellow stuff before , the only fix in my instance was to completly remachine the casting myself as dellows machining was wrong.
#12 Re: urgent help required- Dellow 5-speed problem
steveo Posted on: 2009/4/10 8:08
Yeah it couldn't have happened at a worst possible time! the car was all finished and ready to go on the trailer, but mind you, it was lucky i took it around the block for a spin before i put it on the trailer, i wouldn't have even made it out of pitlane, so i would've went all the way to QLD for basically nothing. But i'm a firm beliver that things happen for a reason! it was never meant to be obviously! Oh well.............. You get that!
I'll definatly give Dellow a call next week to ask for their advice. I have never heard of a thrust bearing wearing out so quick, particulary the standard steel type that the datsun gearboxes have. The only thing i can think the problem being is the datsun pressure plate that i used? maybe that is what chewing the toyota unit?
Not exactly sure? its got me stumped! i'll have to have a look when i take it apart in the next couple of days.
#11 Re: urgent help required- Dellow 5-speed problem
b310gx Posted on: 2009/4/10 6:07
not much help for you at the moment, but a friend of mine got one of the first dellow conversions & one of the things he doubted was this part of the conversion. He got a sleeve machined up to take a standard Datsun throwout bearing & arm. Unfortunately Ron passed away a few years ago, & his Ute has disappeared as his ex-wife was still listed in his will & she sold it off. Typical that it'd happen just at the worst possible time. A call to Dellow on Tuesday might be the go.
#10 Re: urgent help required- Dellow 5-speed problem
steveo Posted on: 2009/4/9 7:06
i bought the gearbox with thdellow kit off siedraught a couple of months ago, and i assume it was working fine when he had it. I made up a clutch aligning tool at work so there no problem with that, got me stumped!
#9 Re: urgent help required- Dellow 5-speed problem
D Posted on: 2009/4/9 6:56
Was this kit working well before?
If not there must be some serious alignment issue.
Are you using an alignment tool or does the box go
straight in?
#8 Re: urgent help required- Dellow 5-speed problem
steveo Posted on: 2009/4/9 6:15
the bearing is an NSK unit, i went and got another thrust bearing this morning for a 3T celica 5-speed and installed it and the same thing happened to the new one, it burnt out in only a few minutes of driving.
What thrust bearing do people use with a dellow 5-speed to A-series conversion?
Would it be better to use the Datsun Steel bearing?
So all this means that the trip to the Datnats is officially been cancelled! what a Bummer!
I think i need a stiff drink! ....... or 2!
#7 Re: urgent help required- Dellow 5-speed problem
D Posted on: 2009/4/9 3:42
Steveo is it a toyota item or an aftermarket item cause I had the same thing happen to celica years ago and it was a 3 year old clutch kit from China or Malaysia as I remember.
#6 Re: urgent help required- Dellow 5-speed problem
steveo Posted on: 2009/4/8 11:51
no it doesn't fit straight on.
The bearing sleeve ID is heaps bigger on the toyota unit, as seen in the photo.
i'll have to go and find a toyota bearing tomorrow!
It had to happen just before the DAT NATS!! Just my luck!!!!
