#5 Re: Coupe Seat belts???
LOWTECH Posted on: 2009/5/4 5:36
Thanks for the info ddgonzal!!
#4 Re: Coupe Seat belts???
LOWTECH Posted on: 2009/5/4 5:34
Hey silvia-specr, where'd you go? I've sent a couple PMs about those possible seat belts... I could really use 'em!
#3 Re: Coupe Seat belts???
ddgonzal Posted on: 2009/4/30 6:38
1200 coupe and sedan use same front belts. The USA versions are retractor belts, but a three piece (separate shoulder belt) design. It works OK, but the retractor is at the bottom of the door and tends to get knocked out of vertical and then jam if the belt is pulled at normal speed.
Much better, easier to use, is two-piece design like the newer 1200 Pickup. Datsun B210 with external retractor is similar but with retractor at the top. Datsun B310 has internal retractor (inside the door pillar) so it doesn't retrofit.
#2 Re: Coupe Seat belts???
silvia-specr Posted on: 2009/4/30 4:59
PM sent.
#1 Coupe Seat belts???
LOWTECH Posted on: 2009/4/29 12:00
Anyone know where I can get front seat belts for a Coupe? Mine didn't come with any, and haven't had much luck in the junkyard. Does anyone sell replacements? I'd try a universal fit item, but I've never seen the stock ones so I don't have any dimensions for comparison or retractor orientation.
