Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#14
Re: Can an engine be over-cooled?
ogyris
Posted on: 2009/5/24 8:51
Yes, what temperature are people running with CA18DETs?
#13
ogyris
Posted on: 2009/5/24 8:48
Thanks everyone,
that was a very interesting read. I never had any idea an engine could be over cooled, and damage the possible result. I always thought a big radiator was better, but it's obviously more complicated. It seems better to use the standard radiator and to stick on some excellent thermo fans so that the temperature never gets too low and when it gets hot, the fans take away the extra heat. Also interesting that the temperature differential between the rad and the engine should not be more than 5 degrees or so.. Ultimately I need to find out: if my thermostat is now broken or mismatched to my larger radiator (The radiator might take the temp below it's operating temperature?) what the actual temperature is (if too low or not) What the optimal temperature is for the CA18 (I heard it was 90 deg?) The radiator is from a nissan R32 btw. justin
#12
jeffery
Posted on: 2009/5/21 7:10
What water temp are people generally running at on their ca18dets? Mine sits almost bang on 80 deg C...
#11
converted
Posted on: 2009/5/21 2:06
yes they can be over cooled, ie a big radiator and no thermostat...this increases wear particularly on the cam lobes significantly.
A big radiator wont overcool your engine if your using the right thremostat. For an A series i ran a gemini radiator with a 80 degree C Nissan factory thermo, plus I ran an oil cooler as well. Both indicated temps were 80 degrees C and thats where you want to be. No mater what the exernal temp was or how hard i thrashed in in a race 80 degrees and wouldnt nove.
#10
Rallytwit
Posted on: 2009/5/21 1:22
On my 720 pick up I used to have to partialy block off the radiator.......during the chilly Vegas winter. I wouldn't get any heat till I was almost to work.
As for over cooling on our Yamaha D-Sports Racer we blew 2 engines not relaizing the motor was over cooled. A friend at one of the driving experiances gace me a huge C&R radiator, sometines the motor would run as cool as 155 F, well at 12,000 RPM's the #4 rod would weld itself to the crank. I found pieces of the rod small end inside the transmission, one curly Q noodle looking small end actuall wedged itself under the started.........a call to a racer I knew who was the engineer for Yamaha's Superbike program is how I found out the problem was overcooling. Tom
#9
dazza1200
Posted on: 2009/5/20 12:16
you really want to run an engine as hot as you can get it without it boiling
look at some late model thermostats with over 100deg C opening. if you lose pressure they boil instantly oil needs to get to 80 deg to boil off acidic impurities dazza
#8
Posted on: 2009/5/20 4:00
Remember the oil temp is directly related to coolant temperature. In most engine designs, the oil runs about 20F/10C hotter than the coolant.
Now if you fit an oil cooler this changes, but the coolant temp still affects it. The heat has to go somewhere, and it won't wait until it gets to the radiator/cooler. Heat transfers anywhere it can: through the alumi head, valve stems, cylinder walls, etc. And if the coolant is hot, heat will flow from it into the oil passages. So if you keep your coolant temp stable, it helps keep oil temp stable too.
#7
Posted on: 2009/5/19 22:50
if the motor is over cooled it can also lead to wear of the rings from my memory and bearing wear as the oil and block etc are not opperating in theoir inteanded o or optimal efficiency range.
This leads to excessive a/f ratio running rich and washing the bores with excessive fuel, leading to oil contamination and the damage mentioned above.
#6
Rezlo
Posted on: 2009/5/19 21:25
As said, over cooling is a problem, but what your saying does not explain over cooling, if your heater isn’t working right your thermostat isn’t working right or you’ve plumbed it wrong….Over cooling would be a oil cooler with no thermostat action or a radiator that is so big that the coolant on the outlet is to cold to let the thermostat cycle correctly, IE ITS MASSIVE... also coolant speed that isn’t high enough or is to high can cause amazing problems.. remember that coolant shouldn’t see more than a 12-14c delta drop from in to out or it will break down very fast causing deposits and all kinds of nasty things (most modern cars only have a 3-4c delta drop.
Start off by checking your thermostat, never run any motor with out a thermostat and be very careful running a low temp thermo in any nissan motor, at most use the 64deg nismo unit but make 100% your ECU is not adding any enrichment from 55deg onwards and use a taper scale up as coolant temp rises to ensure fuel ratio and timing stays the same which it will when your in heavy load or boosting for longer periods of time or obviously traffic, after all a cooler thermostat does not help cooling ability, it just starts the process earlier and helps buffer thermal shock a bit easier. And yes, and engine running to cool has bad efficiency which = bad fuel consumption and in most cases lost power, especially if its running cool due to added cooling system ability, remember IC engines are only 30% odd efficient, 60% of its energy is being lost to the exhaust heat and radiator, by going mad on radiator your actually taking away from combustion heat which robs power, you generally never want to have a engine running to cool as the cooler it is the less efficient it is Just my 2c (sorry the engineer in me coming out )
#5
dattodude
Posted on: 2009/5/19 13:39
My ca18 has always run hot.. darn it..
As soon as I get on boost.. I see the oil temps skyrocket above 110 degrees...at some point nearby...the Autronic starts pulling back the timing etc. due to high temp threshold. I know about this ..so I also start taking it easy. I'm wondering if my waterpump or N13 radiator are questionable. Maybe bugsie's thermostat theory is my problem? Everytime I was going for dyno tunes ..we'd have to stop to let it all cool down. As for initial problem ogyris has asked about ..I'd say stuck open thermostat. You can view topic.
