Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: Valve dimensions?
Posted on: 2009/5/21 20:50
A15 valves are exactly the same as A14. In fact there is no head unique to the A15.
The valves are nomiminally 37mm/30mm In/Ex and 8mm diameter stems. But the actual dimensions are slightly different. If you are ordering custom valves, use these nominal dimension.
#4
Pendles
Posted on: 2009/5/21 13:20
they're not brand new one's, so don't take those measurements as gospel, but they're in pretty good nick.
#2
Pendles
Posted on: 2009/5/21 11:29
A set of stock ones I have here are:
Stem Thickness: 7.95mm Head Diametre: IN: 37.20mm EX: 30.25mm Length: 103.90mm
#1
Valve dimensions?
ROConnor
Posted on: 2009/5/21 11:23
whats the stem thickness, head diameter and length of a15 valves?
