#8 Re: cam grinds?
A14force Posted on: 2009/5/24 10:16
Don't go too wide with your lobe separation angle. The wider that angle is, the sooner the exhuast valve opens. If you've got it opening too soon, you lose too much power out the valve. 114' mite be okay of a nitrous or turbo engine, but I would stay around 112' for a supercharger. just my 2c.
#7 Re: cam grinds?
Pendles Posted on: 2009/5/24 6:55
tighe cams in lowood are good also, they're very knowledgeable on A & L series stuff, and will make whatever you want.
Tighe Cams
#6 Re: cam grinds?
affordableperformance Posted on: 2009/5/24 5:10
I use wade cams, they can regrind your old cam to whatever specs you choose. You want lobe seperation angle of 114+ degrees and duration as large as the power range you are chasing, lift as much as your valve train can handle without coil bind or piston to valve clearance. Dont be afraid to go as large as 230/230 @ 50 if your chasing good power @ 3000rpm+ and have good intake/exhaust. The bigger the cam you run the higher the compression you can get away with due to cyl bleed off. Most people recomend baby 210 degree cams for use with boost but you wont make much power with them, cant even hear there in there. Hope that helps ya bud.
#5 Re: cam grinds?
ddgonzal Posted on: 2009/5/23 19:44
High lift, low overlap. Which is shorter duration than a typical 'race cam'.
Find a cam grinder that does custom grinds. They'll no what to do. Don't they have any in Australia? In New Zealand there is Kelford.
#4 Re: cam grinds?
Dundee1000 Posted on: 2009/5/23 16:41
high lift short duration..
#3 Re: cam grinds?
aidaniel Posted on: 2009/5/23 14:42
ok then ... how bout, does anyone know a decent cam grinder in adelaide that i can discuss this with as the only places ive talked to do set cam grinds and they arent anything special either
#2 Re: cam grinds?
ROConnor Posted on: 2009/5/23 13:53
The cam grinder will be able to grind it to make power were you want it, you wont need to no the spec's??
#1 cam grinds?
aidaniel Posted on: 2009/5/23 13:14
what would a suitable grind for a supercharged application be ... looking to go all out here
