#14 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
nt1200 Posted on: 2010/6/6 11:24
hey man i noticed this post is old but i was just wondering if you still had the carburettors? thanks heaps Nick
#13 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
levey Posted on: 2009/7/9 12:37
Can't believe this is not sold yet.
#12 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
ca18det_man Posted on: 2009/7/9 11:19
Very nice setup and well priced too would cost easy double that to build from scratch. I miss my old JTS A14 nothing like the sound of a sweet revving A series.
Good luck with the sale
#11 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
louix Posted on: 2009/7/7 14:13
will u sell the throttle bodies seperate.... if so how much. pm me back
#10 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
rally1200 Posted on: 2009/6/23 10:09
OK Price.
I was thinking $2500 for the engine only (including flywheel)
or $3500 with Throttle bodies and Extractors
The Engine will be ready for sale in 2-3 weeks after finished assembly and dyno tuned.
Engine will NOT be sold with Dissy.
#9 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
Myaz Posted on: 2009/6/23 1:03
Hey, still for sale? what price are you chasing? PM me with one if you dont want to put it up. Cheers
#8 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
rally1200 Posted on: 2009/6/22 15:43
KAWASAKI GPZ 1100 Throttle Bodies.
#7 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
1200GXman Posted on: 2009/6/22 14:41
Hi rally1200
Sorry to hijack this thread, but I just want to know what throttle bodies are they?
Did they come from a motorcycle and if yes from what specific bike. Thanks. If I was closer I would have taken this engine as it is already very close to what I want out of mine. Hope the sale goes well.
#6 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
rally1200 Posted on: 2009/6/22 13:30
Ok. engine specs
1398cc
A12 Early Block
A12 Rods & 76mm Mitsubishi pistons Flat top with valve reliefs - 18mm Pins
A14 Crank lightened and polished .020" undersized(77mm)
H891 Head ported and flow benched 37mm/30mm valves (results available)
Head fully serviced with 8 new valve guides and seats cut (guides left slightly longer/better life)
JTS Double Valve Spring shimmed up to 85lbs/seat 240lbs/nose with proper double valve spring retainers
Head heavily shaved for max compression 21cc chambers, with dimpled combustion chamber (intake turbulence)
1mm Head gasket & 1.5mm Head shim to drop compression down to 11:1
Set Used GX Head Bolts "13" grade
JTS 176c5 Cam Intake 49/71 Exhaust 79/41 with .4695 Lift
Multi-dowel Adjustable Timing gear
A12 Flywheel lightened to 6.6kg modified for 200mm Clutch/Pressure plate
JTS Headers Modified for 2,1/2" system
34mm Quad Throttle bodies with custom steel/ceramic coated intake
My plan is to finish the engine run it in and then dyno it.
Engine gives Very Good power from 3500 to 7500 and is setup for Pump 98 Fuel
working on a price for engine only or complete setup or make an offer.
#5 Re: EOI, for sale early A12 rally engine 100hp ATW stroked
racetech Posted on: 2009/6/22 13:01
A lot of drooling going on here.
