Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#6
Re: help needed with dizzy
Posted on: 2009/9/19 23:25
i need a timing point does an e15 distributor have the this feature With most EFI controllers you do not need a timing point -- it is only used with sequential EFI or individual coils. Put the controller into constant flow mode and 'wasted spark' mode and you should be OK.
#5
BeastofBurden
Posted on: 2009/9/19 22:58
I know it sounds obvious but have you asked EMS?? Good luck mate
#3
Re: distributor
mitch_dato
Posted on: 2009/9/13 8:52
yea its a ems and on the wiring diagram is says dizzy or sensor
#2
Re: distributor
dat141
Posted on: 2009/9/13 8:23
What sort of computer is it? Some fuel only computers will run on a tacho signal, but most of the newer ones require a crank angle sensor.
#1
mitch_dato
Posted on: 2009/9/13 3:58
hey guy
just in the process of wiring up my new computer and i need a timing point does an e15 distributor have the this feature or do i need a crank angle sensor thanks You can view topic.
