Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#13
Re: Wanted to buy 120y engine brackets
rocky
Posted on: 2009/11/27 23:19
Hi does anybody have 1200 engine brackets to suit?
Regards Rocky
#12
popo1200perth
Posted on: 2009/11/26 9:29
see if you can find the top bracket in the picture.. from memory they go on the right hand side of your engine... on the exhaust side.. that will bring the engine down a conciderable amount.. i had the same problem on my 1000 coupe.
#11
rocky
Posted on: 2009/11/26 6:36
Thanks for your help i checked the thread you suggested and think im on the right track my datsun is a 1981 1200 ute so should have the late model cross member i brought the vehicle with the A14 already fitted and suspect it was fitted with the A14 brackets instead of transfering the stock A12 brackets over ? i may be in correct so any guidance is appreciated
regards rocky maybe like this one Attach file: datsun bracket.jpg (5.86 KB)![]()
#10
Posted on: 2009/11/25 19:15
Rocky, what year is your Datsun 1200? Is it early (1970-1973) or late (1974-1994)? And does it have the original crossmember or has it been changed?
Or somebody just give him some 120Y engine mount brackets If the 1200 ute has the late crossmember they will work.
#9
Posted on: 2009/11/25 10:07
1200 sedan has early type crossmember
A14 is late type. when you mix and match, it is an engine swap and mods are needed. But if you have a 1980 ute and 1980 A14 engine, it just bolts right in, no mods needed
#8
D4TM4N
Posted on: 2009/11/25 9:53
with the 1200 mounts u will just run into the same problem with the deck sitting too high. The 1200 sedan we had in the shop had mounts from the A14 engine but the brackets were mounted on the opposite side of the motor.
Hopefully this helped.
#7
Posted on: 2009/11/25 9:39
I've been researching this, and while I still think you need the 1200 mounts to match the year of your 1200, I'm not sure about the photo.
See details here: Tech: Engine Mounts It doesn't matter which engine you have (A12 or A14), what matters is the year of the crossmember (early or late) and the year of the engine (early or late).
#6
Posted on: 2009/11/25 6:36
A14s were not standard fitment to Datsun 1200 utes -- not in Japan, nor in Australia. So someone swapped the engine, and didn't use the original 1200 engine mounts, but used the ones from the donor car. The beefier mount in the photo looks like a B310 Sunny mount.
A14 and A12 use the same mounts. The ones you need are for the Datsun 1200 vehicle, which will bolt to either engine.
#5
rocky
Posted on: 2009/11/25 6:16
No i would like the bracket like the one in the top picture if i can get one i have the bracket like the lower pic i think its the standard A14 one my vehicle is a 1981 1200 ute fitted with a A14 motor and i would like to get the engine sitting correctly so i will have the room to fit my side draughts
thanks for your responce regards rocky
#4
Posted on: 2009/11/25 6:01
So you want a Datsun 1200 engine mount bracket. Using a 120Y bracket in a Datsun 1200 will make it sit too high.
