#7 Re: Car Doesn't Start Help Please.........
ddgonzal Posted on: 2009/12/22 4:27
The choke is on top
Choke
#6 Re: Car Doesn't Start Help Please.........
Sumith Posted on: 2009/12/22 4:16
Hi Guys
Car was running before 3 weeks , so i don't think so that the fuel is bad, I have tried Carb Test as specified by DD
I am not clear about the carb at all just tell me which is the choke here ,
jpg  Image017.jpg (16.64 KB)
10994_4b3047f836cfd.jpg 352X288 px
#5 Re: Car Doesn't Start Help Please.........
D4TM4N Posted on: 2009/12/21 10:04
How old is the fuel? when was the car last running? Is the fuel clean? , we had a car at work, wouldnt start. took the plugs out, let the cylinder dry abit. put new plugs in and away it went.
Car needs 3 things.
Fuel, air and spark.
on that line, is the carby set-up correctly , with the correct air/fuel ratio?
Is the air filter blocked?
#4 Re: Car Doesn't Start Help Please.........
Mildman Posted on: 2009/12/21 5:01
I remember my engine wont start days....here's the process I followed (just the one in the workshop manual with my pretty pics added)
http://datsun1200.com/modules/mediawi ... _Troubleshooting_Overview
#3 Re: Car Doesn't Start Help Please.........
Sumith Posted on: 2009/12/21 4:56
Hi DD
Thanks, i will go home and check it ,i don't see any Top Mark on my crank pulley but in my engine block has,how do i adjust it ? And i got 56T Transmission box,what is the oil capacity of it ?
Thanks
Regards
Sumith
#2 Re: Car Doesn't Start Help Please.........
ddgonzal Posted on: 2009/12/21 4:16
Spark + Fuel
Remove the air cleaner lid
Push choke knob fully in to dash
and look down in the carburetor while moving the throttle
Do you see a consistent squirt of fuel?
* Yes, fuel is OK
* No, carburetor problem
* Fuel trickles, not consistent, carburetor problem
#1 Car Doesn't Start Help Please.........
Sumith Posted on: 2009/12/21 3:23
Hi Guys
Just Need Help Urgently Guys, Fixed My datsun back it doesn't start
Engine Cranks Properly
Spark is there on the plug
Petrol Pump is working The Carb is half filed with Petrol
But there is no sign of it starts
Push it but still not
Need to Clarify Few Things
The Lower part which we connect Platinum Point(what do you call it ? )on it there are few points A ||||| R Etc, to which point should i keep it ? Could not Check Compression on Today I am gonna to check it, but seems it is ok , What else should i check guys any advice on Please.....
Thanks
Regards
sumith
